Kitimat KLR
So, finally, all the goodies arrived in the mail. I think I got something from nearly each supplier.
1) Doohickey. Used Marknet documents & Eagle Mike parts. No problems at all. The hardest part was installing the torsion spring around the new Doohickey. When I got to see the OE Doo & spring...the spring is broken and slowly being ground by the chain. The Doo is not sitting squarely on the shaft - the top is eroded by the starter ring - which had corresponding grooves on the back.
I now have a spare angled wrench, rotor puller bolt and gaskets (2). I managed to tease off the original gaskets, clean them up& reuse (so far no leaks)
2) Swing Arm & Suspension. Removed all bolts & seals. removed 5lbs of chain oil gunge. FAirly straightforward, some of the long bolts needed some "help" but most came out fine. Added grease to theneedle bearings, cleaned the seals and greased the bolts & reassembled
3) New Sprockets & Chain . Again fairly straightforward. I also replaced the damper rubber that lives in the rear hub.
4) Test Ride - Started first click! The bike is now unbelievably quiet and pretty smooth. Unfortunately, I set the shift lever a little too high... otherwise almost perfect.
The "hook" of the spring has broken off. Note the angle of the Doo on the shaft & the erosion caused by the Starter Ring (on top of the Doo)
