• Welcome to new DualSportBC Forum!
    To Log in on new forum you will need to reset your password first using "Log in" --> "Forgot your password?"
    Sorry for the inconvenience caused, but we trust it's a one time deal.
    If you encounter any issues please contact us at [email protected]
First KLR Run
I B Stryder
I have trundled thousands of kilometers, mostly cariboo chilcotin, but I just got a Klr this summer and this (if the link works) is the first Run. It has a bit of everthing. From blacktop hyway towards the gold rush trails around Barkiville.
I've shared a map with you called First KLR run:http://maps.google.ca/maps/ms?ie=UTF&msa=0&msid=
215450675095240575721.0004d21c95018e8a5d41f
hhmmm looks like links don.t work maybe cut and paste!
will check then try to edit
stryder
I B Stryder
Iknow there has to be a way any help in posting links would be aprieciated will try the river road along the chilko river.
I've shared a map with you called River Road:
http://maps.google.com/maps/ms?ie=UTF&msa=0&msid=
215450675095240575721.0004d268a14bc0f97d1a4
Your right..kind of..
if i copy and paste above it works for me, but if i copy and go to itsends me off to a us map..
thanks for the reply
I B Stryder
Yeeehhaaa you got it working
Hmmm? will this work?
http://maps.google.com/maps/ms?ie=UTF&msa=0&msid=215450675095240575721.0004d268a14bc0f97d1a4
Right click ^^ , and "open in a new window"
Yup, it does.
And if you don't have a 'pop-up-blocker' just clicking on the link should work. I have a popupblocker so I have to do the other routine.
:clap: Thanks
ok so now .. how did you post as a link.. shows in blue?
thanks agAIN
OH SHOWS LINK IN THE SCRIPT DUUHH. SORRY Now to be able to shift into 2nd
250ccforme
I'm running the Mud Pit Brown theme so I've got a black screen with white text. Some stuff in your posts was hard for me to see until I did the "click" and "drag" to highlight it, then it shows as white text in a green background. I think links show in a different colour in all of the themes.
