rock chip in case
NI230L
hey went on a ride today and had a rock ding off my left (shifter) side case and now its slightly weeping oil what should i do new case, machine shop(can it be welded),jb weld any thoughts,,, thanks
If you properly prep the case around the ding by rasping it to roughen the surface JB weld will usually do the job.... I've used it on several case repairs with great success...
island hopper has the fix. but it's probably worth the time and a gasket to take the cover off,clean it inside and out with brake clean,rough it up and patch it on both sides. clean and oil free is the important point here.
NI230L
Photo of case. I am going to jb weld it just not sure about doing the inside as well.
Mad Max
If you are going to take it off + clean it anyway,Frankie at Micron Machine up in McNeil used to be a bike-freak and could TIG you up good as new!That is if they are even there any more.
Good Luck
Max
NI230L
Yep he is still there i was wondering if the case was tig weldable...
