I'm looking for some temperature related feedback from ktm owners.
I am installing a Trailtech Vapor speedo that comes with a temperature gauge that you splice into one of the radiator hoses. My question is, which hose is my best bet to splice into. I would like it to be the hose that will give me the hottest temperature, so exiting the motor I would assume. Just not 100% certain which one that is on my 2002 exc 520. Also, is there any downsides to tapping into this hose? if not, which one is best?
Secondquestion; the computer can be set to indicate two temperature warnings....warning temp (yellow light) and better-pull-over-light (red). What are your thoughts on these ranges? The only info related to my question I found stated that a guy on a 580 hadhis lightand auto fan comingon at 185f and off at 175f. What is a good operating temperature range, and where are the danger levels at? I plan on installing a fan with manual switch, so would like to set the yellow light to indicate when to flip the fan on.
The computer can also indicate a 'redline' for RPM, what are your thoughts on this?
My research discovered a point about a stock 525 making max power at 7200 and dropping off at 9,000. Can I expect similar numbers for the '02 520? (pro circuit t-4 exhaust).
Thanks for the help :clap:.
db
db
