Alot of things go into brake pads. How much noise will they make (number 1 comeback in shops), how much dust, how hard will they be on the rotors, how heavy a load are they expected to stop, at what temperature range will they be expected to work, how will they work when wet or dirty? Like dual sport bikes it's a compramise and they have to be priced at a level the consumer will pay (why people cheap out on brake pads, rotors, calipers is beyond me). There are various terms used to describe the brake pad compounds and it's quite confusing. I hope the following helps and hopefully someone more mechanically inclined can provide a more scientific answer. Myself I use a semi-metallic. Your owner or repair manual should point you in the right direction. Good luck.
This is taken from the Car Bible website
Organic
These pads are well-suited for street driving because they wear well, are easy on the ears, don't chew up the rotors and don't spew dust everywhere. They're favoured for your average family saloon because they work well when they're cold. Of course the drawback is that they don't work so well when they get hot.
Semi-metallic / sintered
This is a good compromise between street and track. These seem to be the pad of choice for sportier vehicles such as the Subaru Impreza WRX. They won't work as well as organic pads when they are cold, so you need to be a bit wary of the first couple of stops. Conversely they do work well when hot. Occasionally the weak link in semi-metallic pads is the bonding material that holds the friction pad to the backing plate. There have been occasions where the friction material has come away completely. That's infrequent though.
Metallic
These pads are typically reserved for racing or the extremely rich. They squeal and dust like crazy, are hard on rotors and don't work well when cold. Also used on heavy trucks (think Ford Superduty) with high heat demands. Hard on rotors.
Ceramic
Ceramic pads still have metal fibers (about 15% vs. about 40% for semi-metallic) but they are copper instead of steel and therefore cause less wear and transfer heat better. They don't fade as easily as other pads, cool faster, last longer, and are effectively silent, as the sound they genereate is outside of the human range of hearing. Dogs will go crazy thought. The dust created by ceramic pads is also very light in color so your wheels look cleaner.
