Carb removal
RoscoeP
I have a 06 DRZ 400 E and am going to jet it and do the idle mixture screw. I have the tank off and am looking for some general tips on what stays on and what comes off like the air box etc. It is the FCR 39 mm carb on this bike. Thanks:hb:
Leafster
Turn off the gas at petcock
Drain carb by loosening the little screw on the side of the float bowl
Loosen throttle cable nuts, remove throttle cable from carb.
Loosen clamps on boots at either end of the carb.
Wrestle the carb out place on the bench
Change those jets, cut hole in the airbox, put it all back together and rip it!!!!
RoscoeP
Thanks for the reply, I got it done but havn't fired it up yet as the exhaust is off and apart. I will repack it tomorrow and cross my fingers. Thanks again. Cheers Roscoe:hb:
RoscoeP
Well I finally got to fire up the bike. Started right up and ran so much better. Didn't have to leave the enricher button out very long and when I pushed it back in it idled nice and smooth. No stalling pulling away or when putting in gear, I am so happy. Went for a little burn and it ran great, I could not be happier. Thursday I will put the skid plate back on and a couple of other small things to do. Then put on my RoscoeP decal and I'll be ready to go. Cheers :hb:
