Hi,
I have a drz and am putting a clarke tank on for next season. I found a replacement second-hand vacuum petcock. Once I had everything tightened up (Tight!) it seems to have only a small (1/2 cc per day) drip.
So here's the question - Is having a petcock somewhat redundant when there's a valve in the float tank?
Specifically for me - Given that the carb (in my case a Mikuni BSR) has a float valve which should shut off excess fuel, do I need to worry about this slight fuel drip (I read the horror stories of fuel drips from vacuum petcocks destroying engines)?
Update - posts on Thumper talk suggest the drip needed to be fixed - or another petcock. Dismanteled the petcock and cleaned it again - this time no drip - YeeHa
Thanks for the help
Neil
Thanks for the help
Neil
