Here's an alternative to the"bypass" or "clean" dilemma. One of my trademarks is the "Keller Compromise" which is finding the way to have my cake and eat it too. (VBG)
I simply added a double pole switch (one which handles two separate circuits), wired in so that the switch will bypass the safety switches if needed but allows the safety switches to be retained and used as the maker intended. I like the sidestand safety switch as I have seen several accidents from someone riding off with the side stand down.
If you are into this procedure, it follows. It sounds more complicated than it is because I tried to be detailed.
HIH
Norm
Safety Switch By-pass Switch
Parts list:
1) DPST (Double Pole Single Throw) bat handle toggle switch
2) Rubber switch handle rubber boot
3) Approximately 10 feet 18 gauge wire
4) 4 crimp connectors, eye type to fit screws on switch
5) 1 crimp connector, eye type to fit 6 mm bolt
6) Rubber tool handle dip or silicone RTV
Procedure:
1) Crimp and solder connectors to three 8-inch wires and one long wire
to reach CDI module behind radiator overflow tank. Crimp the 6 mm eye
connector to one 8-inch wire.
2) Attach the long wire and 8 inch wire with 6 mm eye to one side of
the DPST switch (one switched set of terminals) and the other two 8 inch
wires to the other side.
3) Dip the switch with wires attached into the rubber compound or
alternatively coat with RTV, the body of the switch and wires where
attached to switch. The complete switch body should be coated but do not
coat more than the first few threads of the switch mounting tube.
4) Set switch aside to dry.
5) Remove plastic cover over kickstand switch.
6) Remove side covers, seat, front radiator and rad tank covers.
7) Disconnect fuel hose and vacuum hose to fuel tap.
8) Remove fuel tank and check to make sure that the fuel tank mounting
rubbers (hockey pucks) are still in place. Remove the plastic shield in
front of radiator overflow tank.
9) Locate the CDI box and follow the wire harness to the middle plug
in the wire plug mounting plate and unplug the bottom plug that is the
bike end of the wiring harness.
10) Use a pick or terminal disconnect tool to push the lock finger back to
allow the red-black wire to be withdrawn from the plug body.
11) Push the starting relay upward to unhook from the mounting blade and
pull the relay and wires out in front of the side stand switch. Unplug the
wire plug from the starting relay (4 wire plug below starter solenoid) and
use a pick or terminal disconnect tool to push the retainer finger back
and remove the black and yellow/red wires on the same side out of the plug
body.
12) Solder the two 8-inch wires on the same side of the switch to the
black and yellow/red wires from the starter relay plug. I soldered them
carefully to the top crimp of the wire connector so that the connector
will fit back into the plastic plug body. This will allow the starting
relay to operate normally unless the switch is closed. When the switch is
closed the relay will operate regardless of the clutch or side stand
switches.
13) Solder the long wire to the top crimp of the CDI connector in the
same manner as above and return the connector to the plug body.
14) Remove the 6 mm bolt (10 mm head) from the bracket near the starter
relay’s mounting position, place the 6 mm eye connector onto the bolt and
reinstall the bolt.
15) Last step is to mark and bore a hole in the bottom front of the
plastic side stand switch cover which was removed in step #5, locating the
hole so that the switch will clear the bottom of the starter relay and to
the (bike’s) right of the side stand switch. There is ample room.
16) Test the switch by placing the bike in gear, side stand down, choke
on, ignition switch on, etc. Then, tip the KLR toward you so that the rear
wheel is off the ground and hit the starter. If it fires up, note the
switch orientation. If not, flip the switch and it will go now.
17) Reinstall the covers, tank, seat and such using Loctite and or RTV as
desired.
This set-up will allow a near idiot (me) to use the safeties as designed
but to bypass them at a moment’s notice if one fails. The location of the
switch and means of connecting will allow it all to be removed with nearly
no residual damage if desired. The location will also allow the switch to
be operated while holding the front and rear brakes as if stalled on a
hill because the switch will be easily reached with the left hand.
There are likely more elegant solutions to the safety switch issue but
this may be useful to someone
