dr 200 oil change
mike_123
decided to change oil on wifes dr 200 today for the first time and i have no manual for this thing
ive drained the oil from the 2 drain plugs on the bottom removed the plate with the 3 bolts and cleaned the screen and changed the oil filter
my question is do the crank case and transmission share the same oil and if so is there more then the one place to add oil also is it just the one sight glass to check oil level for both trans and crank case or is there another fill line to check
