I have a DRZ400S with 22k Miles on it and it started miss firing or hestitating on the freeway when cruising at about 60 MPH once it go warn (about 15to 20 minutes of riding). It was almost like the kill switch was being flicked on. It has been getting worse and not once it is up to full temp it misses in a larger range of about 1/3 to 1/2 throttle under load. In neutral is done not miss.
I tried cleaning out the carb, ended up replacing he float value seat and resetting the float level, that did no t fix it.
Replaced the coil and spark plug wire think that that may be shorting out once it got hot.
Neither of these changed anything.
Has anyone run into this issue before and have any suggestions?
