Engine oil for Air Filter? (DRZ400)
Floored
Looking at the manual, it is recommending Engine Oil for the airfilter. When I inquired at the shop about what to use, they sold me the sticky air filter oil. And I used it a few times, till I got access to the manual. Could I have damaged my bike as a result? Do some still recommend the sticky stuff?
So.........what is everyones' thoughts on this. What are you using?
Kuzzy
I've used both. I feel as long as you service it regularly you should have no problem. I think you would notice a decrease in power if the sticky oil plugs up too soon.
Saltspring Island..........Its GREEN over there isnt it?:)
You should check out the No Toil Filter and Oil.
Cleans with soap and water, EZ on the environment:dr:
Just havin fun check it out anyhow http://www.notoil.com/
