F800 GS Bent Side Stand Queries
Redhed
Through no fault of her own, my 800GS took a nap during transport, and bent her side stand. Some questions for those who have been there:
1. Will I have to mess with the sidestand switch in any way when I remove bent piece? (I have intact centerstand)
2. What material is the side stand made from? Now is a good time to lengthen and strengthen said appendage, and being a non-welder, wondering what are my options?
Appreciate any advice and assistance. (Note to self: buy stronger tie-downs and don't assume it is good enough):confused::confused:
W RON
I would think you would what to have it fixed. I wouldn't do with out a side stand.
Most side stands are steel, take it to your local welder, I'm sure he could fix it.
Ron
triplenickel
Is it a mechanical or hall effect switch? A 2 wire mechanical one should jumper out pretty easily, if it's hall effect take the magnet off the kickstand and tape or somehow secure it over the sensor temporarily. Post a picture of it if you can.
Edit: I just did a quick search and it looks like connecting the red and white and leaving the brown alone will do the trick.
Here is a link to how to tie down your bike
Although you have a big bike the same basic principals apply
With the 800 you probably have the lower fender which will not allow you to use a suspension block, so do not leave you bike tied down for any length of time (not good for the suspension) Use 4 straps on the front and try and strap from the tripple tree not the handlebars. Two straps forward that should do most of the work and the safety of two straps going backward, this will keep the two forward straps from coming unhooked by accident (you already know that) Then finally a couple of straps from the footpegs to the back of the trailer, this will make sure that the bike does not go forward under emergency braking.
Note when you travel the sidestand should be up, it was never designed to be used during transport.
http://www.dualsportbc.com/forums/showthread.php?6712-How-to-tie-down-your-motorcycle
Mad Max
If you are not in a hurry,next time you ride through Nanaimo P.M. me + I'll get ya fixed up for free.I ALWAYS like to help out the "Old Farts"
Max
ToadRide
Hey Dave.
My sidestand slowly bent until the bike was almost falling over when my bike was new. Rick removed it, heated it at the bend and pulled it back beyond the new position. A little Tremclad and it has been better than new since.
Redhed
:clap:
Max
Hey Madman Thanks for the offer. I found a former Tahsis mill welder (DonB) who has fixed me up with a stainless (no less) kick stand. Stronger than OEM. That's the good news. Built it longer than OEM, now She wants to go to sleep on the high side when panniers are on. Back to the drawing board and cutting torch. Had a good ride up to Winter Harbour this weekend via Woss. Those roads would suit your style of riding and exploring. I understand the wood is pretty damp at ORCA, and was looking for someone to help with the fire by the river. See you at the Routledge, if not before. Thanks again for the help to the Old Farts Union.:clap::clap:
Redhed
Tom
Really appreciate the link and the advice. I got away with it once, and assumed that was the way to go. Lessons learned, eh?
Redhed
:D
Hey Dave.
Hey Doug I guess you survived another Victoria Winter. Rode up to Winter Harbour this weekend. HarbourMaster said they had a 5 foot wave during the Japanese quake, with a 60' whirpool in the center of harbour. Great ride, but I still think Tahsis should be the Western Terminus for the Trans Canada trail. See you at the Orca?:D:D (Kevin should be back from SA and be able to tell tales...)
Mad Max
: I understand the wood is pretty damp at ORCA, and was looking for someone to help with the fire by the river. See you at the Routledge, if not before. Thanks again for the help to the Old Farts Union.:clap::clap:
Sorry I won't be ORCA'ing with you +your punk kids. Maybe we can ride up to Routledge together.I could even be your roomie eh .Do you know if they allow Redheds and REDNECKS to have bonfires there?
