I 2nd the motion....... I've been running supreme in my '01 KLR, mostly because the PO said it had been on supreme from day1 and recommended I do the same. The manual says 87 is usually fine, but if you get 'pinging' to go with a higher grade and it even includes some algebraic looking formula to calculate the optimal octane for your engine...... How much will a few points of octane effect things either way I wonder.... as much as it will effect my wallet over the next several decades?
edit...... this is copied and pasted from Bigcee.com's KLR FAQ page....
Should I use hi-octane fuel?
Only if your engine pings under load. High-octane gasoline does not contain any more energy than low-octane, and is intended to reduce the possibility of pre-ignition and detonation, which can be a problem with high-compression engines. An engine can gain nothing from higher octane gasoline if it is not designed to take advantage of it. That being said, any change that increases the peak compression pressure (i.e., increasing the charge of air) can cause pinging, requiring higher octane gasoline. These changes include opening up the intake path, increasing valve size, intake cam duration, etc. However, these changes are usually small, and can also be cured with jetting. Excessive carbon deposits in older engines can also increase the effective compression ratio, or provide hot spots for pre-ignition, requiring higher octane gasoline.
