J
jf350
Me again. First off, thanks to Big White DR & malachi for your advise, I followed it and found a host of problems from a "greased" air filter to a rip in the carb diaphram (dual port carb - 1 side mechanical 1 side vacuum). I cleaned the tank, emptied and cleaned the carb and set the float and replaced the ripped diaphram ($90 yamaha).But nothing has fixed it, if anything it is worse. the bike will idle fine and can rev it in the drive way but has got NO power on the road. Can't even get it out of 1st gear. I then checked the valve lash which is at .008" hot. Does anyone know what it should be? does anyone have a manual for this bike that they would like to sell me? Need some pointers or maybe is should point this bike into the river and get my cr480 back. ANY help would be appreciated
