How many links does your TE610 chain have?
C
Crongo
I was hoping someone could tell me how many links (or pins) their TE610 drive chain has? According to the manual it should have 112 but mine has 114 (which I assume includes the master link). I have very little room to adjust my chain for wear as from new the adjusters were nearly all the way back (luckily the chain has neverneeded much adjustment). Now I have tried to put on my nice,recently purchasedsupermotard wheels and I can't get the chain tight enough as the sprocket is even smaller (43T). I plan to remove 2 pins but I was curious if this was a mistake on my bike? Thanks.
Crongo
F
franhoser
Crongo
Sent you a PM on this. Stock setup is 112 for SM and 114 for TE on chain. Stock Sprocket Setup is 15T and 45T for TE, 16T and 45T for SM.
I had a the 112 links and work for both45T and 43T with the 15T counter.
So yes just remove two links and it will work perfect.
C
Crongo
Hello Franhoser,
Excellent, that makes sense. My shop manual does not mention this difference between the TE and the SM. I should be good to go tomorrow. Thanks for your help and your PM on this.
Crongo
