Installing new LED tail light/ signals. 09 450 exc
zoo
Hi all,
Just ripped off my 09 exc plate holder in the first 3 hours of riding. Like didnt some one at KTM think about this.
Anyways, does anyone know exactly what electrical parts I need to wire this up. I've been told I'll need inline resistors but is one fit all for these.
Any help would be great. thanks.
scottbc
I broke mine on the first ride as well. Only the small bottom part ripped off though. I made up a 1/8 abs backing plate for my plate with a 1/4 spacer. Then I heated the abs up with a heat gun to put more angle on the plate. Works great, I've made one for a friend as well.
If you are replacing the whole assy. most people order the euro spec tail section from KTM. I believe that it is pretty inexpensive. There are part #'s ect. over at KTMTalk.
Scott
Mud-Ectomy
zoo wrote:
Hi all,
3 hours:shock: It took me 7 hours to rip off my left turnind and plate mount. I hooked up a flush mount rear LED turnind I had laying arround the shop. It works but does flash at a quicker rate. In the past when switching to LED I have changed the flasher assembly to maintain the same flash rate. I am not sure if the brake/Tail light would need a resistor.
Like scottbc says I have heard that KTM hutt has the euro assembly which is supposed to be improved.
Mud
you can buy a led flasher through lordco if you need one. grote is the brand name. much cheaper than the top secret stuff the m/c specific companies want to sell you.
mike_123
https://www.ktm-parts.com/mm5/merchant.mvc?Screen=PROD&Store_Code=K&Product_Code=D4558618&Category_Code=SBBDRC
https://www.ktm-parts.com/mm5/merchant.mvc?Screen=PROD&Store_Code=K&Product_Code=78014040044&Category_Code=PPELHL
ktmparts.com has what you need
took 4 days to get it to my house and its a bolt on replacement
signals also come in orange and you need to splice the factory plugs to the wire but generally a pretty easy install
and they look great to
the plate bolts on under the tail light keeping it up out of the way but i used part of the factory metal bracket for some backing behind the plate
marcveinotte
Zoo, When you get the bike out of the shop, wheel down the road to our place..we have what you need.
