K&N Air Filter
ktmken
What is the opinion of K&N air filters for a DRZ400s. The bike I just picked up has a K&N air filter and I am not sure if that is good or bad.
Some people love them and some people hate them.
The bike has been jetted and dyno'ed with the filter so jetting isn't an issue.
Some people feel they let too much dust through the filter.
Anyone have an opinion one way or the other.
The PO did give me the original filter, so I can always go back to that.
KTMKen
scottbc
Ken,
Common consensus seems to be that K&N's are notgood on a bike in dusty environments. Oiled foam with a filter skin is the best. I've been using No Toil products and they seem to work great.
I was on a trip last year in Nevada and area. My friend had a K&N on his KLR that was installed by the previous owner. We wasted hours as he had to clean his filter regularly. He even devised the sock mod. He was cutting and oiling bands of his socks so that they could be used like a filter skin. I think that the oiled foam just has a greater surface area to breathe through.
This saidI didn't even have tochange a filter skin in 1700K of dirt. Now there is obviously a difference between a KLR and a DRZ. The DRZ filter is huge in comparison. For my money I'd ditch the K&N. Sell it to some guy with a motard who only rides pavement.
Scott
I had a XT550 that had a K&N on it. Never had a problem with it....no compression loss or power loss. And I rode with mx'res all the time.
On the 950 the filter I have is like a K&N but a different brand.
IT was installed in the spring and is performing great...will clean it this week though...
Pays to keep out front ;)
I like them (wheres that "shrug" emoticon)?
sparklr
KTMKen
scottbc wrote:
Ken,
Scott
I would suggest that the K&N filter is fine for you. As your bike is jetted and dyno'd for a specific elevation range for the K&N already, it make not like the stock filter. When you start riding, perform a test. Put the old filter in you pocket. Create a riding loop for yourself that takes you through several drastic changes in elevation, do the loop trying out both filter options and see which one feels best. Also repeat for different weather conditions, air temperature and humidity also affect air mixture characteristics, which are ever changing from the jetting/dyno set up. You have to find a compromise.
I think setting up jetting for K&N can have its issues. First, the setting is done with a clean filter at a given elevation and air characteistic. This of course varies once you leave the confines of the shop. I believe the most effective filtering performance of K&N type of filters is achieved once it is slightly loaded, again not the same set up as jetted and dyno'd for. So you have to pick which works best for you.
An econo filter skin option is to purchase some nylon stockings to slip over you filter. When they are dusty you just pull it off (the air filter that is) and snap it like an elastic and reinstall.
ktmken
I like that idea.....I think I will try it....
"Honey...next time you are at the store, can you get me some nylons"
:D
KTMKen
S
SmokinJoe
i use a k&n air filter i havent had any problems. I'm sure there is a risk because it does pass air through faster than a oiled foamy filter, but i try and not to follow too closely behind quads and stuff on really dusty days ride at the front, i cant see bikes producing enough dust to be a problem.
however i dont think there is any noticable difference between the 2 filters.
