D
Darren klr
Hi everyone,
I just finished installing a Progressive shock and fork springs in the green meanie and had a little trouble with getting the correct fork oil level. I am hoping someone can clarify this from experience.
I drained the forks via the drain holes on the bottom of the legs and got roughly 355 cc of fluid from each leg. The Clymer manual states that in changing the fork oil without dissassembly , they require 355cc of fluid. "Everything peachy so far"
Now the part that hurts my little brain. The manual states that with the correct oil volume, it should have an oil level of 190mm below the top of the fork tube. I got a measurement of about 290mm (with the springs out and the forks collapsed as per the manual). Anyone got any ideas?? I am wondering if the 190mm in the manual is just a typo.
Took it for a quick tootle around the neighbourhood, and with the preliminary suspension settings I could not believe the difference . It is a different bike, and I havent even played with any settings yet!!!
Thanks Darren
Thanks Darren
