Hi North:
I think your bike is normal.
Clutch plates work in an oil bath. Cold oil has a higher viscosity than warm oil, and the clutch plates will squeeze together tighter with warm oil than cold. This is often why a clutch will feel notchy or even slip a bit when first starting out with a cold engine. The clutch friction will heat the oil in seconds, and allow the plates to seat, but initially there might be less clearance in the clutch pack.
Also, clutch plates and spacers may have a slight warp when cold that changes as the bike warms up. With the high mechanical advantage a very small change in the clutch can result in a large change at the lever.
I think this is true on most bikes and sounds normal to me. I like to have lots of slack in the lever, as long as I have full disengagement when I pull in the clutch and that's about as good as it gets. I adjust it when the bike is hot and running.
another .02cents
Sparkle
edit:Once the weather gets warmer, you might not notice a differance.:ss:
