klr front forks
D
dooveman
Did a post ride inspection this morning and found oil all over my right front fork. I think I must have blown a seal. Never worked on the forks before. I have a Clymer manual and I've been to mark.net site and I'm sure he has something but I am looking for any advice. What supplies do I need to get from Kawasaki? What oil do I use? Any advice is great.
Thanks,
Brian
I started tryong to do it the" easier way"
After some hassel and frustration I got out the tools I had made to do the job right. Years ago, the first time I had to do the forks, I took one fork to a bike shop and asked them to take it appart..$30. Now I had all the parts and knew what tools to make. Special tool consisted of welding a bolt, that took a 15/16 wrench, on to the end of a 18inch steel rod , and weld a "T" handle on the top.This fit down the tube and held the inner peice while an allan wrench was used to un-do the allan-bolt at the bottom of the fork.
It works great..use a vise also.
I re-assembled using a 15W fork oil instead of the 10W the manual called for. I also added and extra 100cc's, I think it called for 550cc and I installed 650.
I also installed air zerks on the caps and run 5 to 7 psi in the forks.
This set up works prety good on the DR650....now all I need is a fork brace.
okmike
I used this method and it was pretty easy...
I tried this procedure yesterday and could not get the fork seals to pop at 100+ PSI. I figured if the seals can handle that much pressure maybe they were still ok, so I just ended up changing the fork oil.
Do you recall how much air pressure you required to get your seals to move?
I'm assuming you removed the fork seal retaining clips?
I'm not sure of the pressure it took to get the seals to pop but it wasn't a huge amount. Just apply air pressurein small increments and watch for the seal to move.
okmike
Heh, heh .. yeah the clips were removed, I almost didn't though, doh!
I added air in 5-10psi increments from 30 up to about 110~120 and couldn't detect any movement in either of the seals (tried both forks). I'll probably have to give it another try if I notice clean fork oil oozing down the fork legs.
D
dooveman
Well, thanks for all the tips but after reading this I decided to just bring it in. The service department said that they may even cover it under my warranty. I think it just expired last week but they said they will beg Kawasaki to cover it. We will see. Otherwise it will cost $150. Less if I take it off the bike first.
Brian
okmike
A long weekend ride to the coast confirmed that I had to replace both fork seals sooner rather than later, so I just gave this job another go.
This time success! I used a decent bicycle floor pump and popped both seals no problem: one at 70psi the other at 100. I suspect the air pressure gauge on my $5 PA 12V compressor isn't ISO9001 certified :tup:
