spring in oil filter resevoir, klx 250
omi
I just did an oil change and found a 3/4 inch long spring in the oil filter resevoir. I cant figure out where it came from?
speed2101
It goes behind the oil filter in the filter housing.in the middle you will see 3 raised bumps it goes in the middle of them and then the filter.you can use a little grease to hold the spring in place then put the filter back in.
omi
Thanks speed, that little bugger was annoying me. The manual makes no mention of it
