Top speed of the 99 DR650
P
Pirate
Should have saved this one for April 1st !! Nice try though.......;)
I couldn't figure out how this happened.
Someone said that if the GPS looses the signal for a while, when it comes back on it compairs where u were...to where u are, and that the GPS sees it as being only a split second of time. I remember loosing the signal for about 5km, maybe that is what happened.
hehe....sure had the wife going though. I showed her and asked if she knew what that was in mph. She said " I don't even care what it was..U shouldn't be driving that fast.:wi:"
It was actually on my last service trip in the truck. Not on the DR
C
Curt
I am sure that you were exceeding the posted speed limit and how did you get that diesel to go over limiter? Remember, your boss looks on this site, wouldn't want ya to get into trouble................:wi:
Cedartree
i'm curious too, i have yet to see a 6.0L in an overloaded service truck (must be an F-450 you drive) set a code for over speed/ max rpm reached... they just don't go that fast unless they are maybe falling into the Grand Canyon. what is the terminal velocity of an S-Duty anyway?:)
2007 F-550, 6L turbo
Looking at the rpm to road speed I think it "runs out of rpm" at about 130kph, 3500rpm. AT 115kph it still has a lot of go.......4200kg rear axel and 2100kg on the front is it's every day girth and 18mpg. On the level I don't think it would have a problem reaching "maximum velocity" in 6th...just give it a k or 2...or3.
