Valve specs for a 2008 KLR 650
Yes I know the manual says no need to check the valves till 24,000 kms. on the new 2008 model.
But i plan to check mine before then, and would like the specs please.
So if someone with a manual would be so kind as to give me the clearance specs for both the intake and exhaust valves I would greatly appreciate it.
WOOHOO, I found out the answer.
For the intake the setting is between 0.10 mm and 0.20 mm
and the exhaust is from 0.15mm to 0.25 mm
I wish I had pulled the side cover off before and look at the sticker inside it...DOH
