Water Pump leaking
J
jeffzee
Looks like i am gonna need to repalce the water pump seal on my KLR, should i replace the oil seal at the same time? Is this a somewhat easy job?
Thanks guys!
Jeff Z
2002 KLR650
Norm
As long as you're in there, may as well change both. The job isn't rocket science, just watch out and don't break the water pump shaft by over tightening the nut which retains the impeller.
The Clymer has a good break-down on this task. If you need help, check with the DSN_650 group on Yahoo. If you're near Chilliwack and need help, let me know.
Norm
J
jeffzee
Thank you Norm, i am going to pick up a Clymer manual and replace it all while i am in there.
Jeff
