hey everyone, still trying to dial in my carb but running into a lot of issues.
Things you should know:
-stage 1 cam
-uncorked air box
-full FMF pipe exhaust
-side panel cut out
-68s Pilot Jet
-180 main @ sea level @ about 25 deg C (77F)
-needle clip 4th down
Ok, so my bike usually cuts out at IDLE when it gets hot. I'm almost certain it is because my bike is running too rich because when it is dead cold and trying to start with choke ON it runs for 1-2secs then dies (yes choke in correct position). What is also weird is my air/fuel mixture screw is ALL THE WAY IN and this is the only way to prevent from cutting out. But then it gets even more weird, the bike pops a lot on decel which usually means running lean. I find idle can be all over, sometimes at a nice health 1500-1600 (stage one cam seems to like that idle) and then sometimes it goes up to 2000rpm to idle
What I have tested:
Spark plug
ignition system, healthy bright spark
air intake leaks (used a propane tank and sprayed around the sealing boots)
Ultrasonic cleaned the carb, blow air through orifices
float level looks pretty good 16-17mm -ish
valves lash checked 0.006" IN / 0.008" EX
What I plan on testing next:
65s pilot
cam shaft position at TDC, maybe it was installed a tooth off?
Does anyone have a stock XR650R carb I could borrow or purchase? Seriously getting desperate, can pay in beer/food/money
-stage 1 cam
-uncorked air box
-side panel cut out
-68s Pilot Jet
What I have tested:
Spark plug
65s pilot
