Bummer. If you need a hand give me a post and I'll try to walk you through it. Or come up fora tech day.
Have you done the Doohickey? If not, it would be a good time to do both as you are part way there.
The skinning of the original grommets is a PIA but not rocket science. I have found that the easiest way to deal with these molded-in-place grommets is to slice the grommet across, parallel with each wire down to the surface of the wire using a sharp shop knife. When the surface of the wire's insulation is reached, carry on around the wire, cutting the grommet away from the wire's insulation while keeping as close to the insulation as possible.
The grommet can be bent open quite well in order to gain clearance to work as one goes around the wire. At the 1/3 way point, it is time to start back at the top and go around the other way as it is possible to tear the grommet if too much pressure is applied.
I use silicone RTV to coat the wires and inside of the grommet holes. On installation coating the outside of the grommet with RTV usually does the job. Go easy on the RTV so that big globs aren't dropping inside the engine.
Removing the wires from the wiring plug is also not a big deal. Each wire terminal has a small finger which is bent outward from the terminal before installation. The finger catches against a slot in the plastic plug to prevent the terminal from being withdrawn from the plug. In order to remove the terminal from the plug it is necessary to press the "finger" back against the body of the terminal. Once the "finger" is pushed back, it will remain there and the terminal can be withdrawn from the end by which the wire enters the plug housing.
I have special tools made to manipulate the terminal retaining finger but a thin pick of other implement can be used. The important thing is not to wedge the hole enough to damage the plug.
I recommend that you buy six new spade lug connectors so that you don't have to go through the exercise of prying the terminals open to release each wire and reattach to the new stator's wire. Regardless, I recommend that you solder the wires to the terminals as this absolutely prevents the connections from corroding.
Another advantage of buying new spade lug terminals (make sure you get the type with the retainer "finger") is that the old statorcould be much more easily reinstalled if needed.
Oh, yes, the instructions were not clear as to which of the two ignition wires (three yellow stator AC wires) goes to which colour wire in the new stator harness goes to which colour in the harness plug. I've misplaced my notes so will have to find them but it's not a big deal as the worst which will happen is that there will be no spark and the two wires will need to be removed from the plug and reversed.
I can let you know when the notes are found.
HIH
Norm
