DRZ Jetting Woes
P
pancho del rancho
I've been at this one for a couple weeks now with the help of some local rider/mechanics and even though there are other local bikes set up the same and running strong none of us can seem to figure out my problem. Hope you can help. I live at sea level, Bellingham, Washington.
'05 DRZ400S
stock exhaust
3x3 airbox mod
Dynojet fuel screw, needle and clip parts (all properly
assembled as per the diagrams)
140 main
25 pilot
clip on the third notch from the top (tried the 4th first, didn't work)
Revs out through the top end real nice but idles poorly, bogs right off idle, and displays leanness in the form of a mean hanging idle that won't settle down until I turn the fuel screw almost all the way in to seated, and that's with the idle adjuster backed all the way off. It acts somewhatlikea vacuum leak but the boot from the carb is fine.Yesterday I pulled the carb for the fourth time, tore the whole thing apart and reassembled everything meticulously, but no dice. Burned said to make sure the tip of the fuel screw wasn't broken off in the carb, and it isn't.
Any advice at all would be much appreciated. .
B
beevel
If your turning your fuel screw in, then you are making the pilot circuit leaner. I would try to tune using your stock pilot jet, go back to clip 4 on the needle and if the bog persists put the stock slide spring back in.
I had my bike setup with the "burned" spec jetting, 25 pilot, 3X3, 140 main, 4 th slot on the needle and I had a lean surge on the freeway, I ended up putting my 142.5 main back in and the bike runs excellently, my point is that not all bikes are the same, different valve specs, etc... All these can make a difference to the state of tune of a bike.
I don't know if this will work, but its worth a try.
Have you checked your float height? Check and see if it's adjusted to spec. Fuel level to low in float bowl could cause a lean condition to high would be rich, some times if the needle valve assembly is worn you end up with an unstable fuel level and this can cause all kinds of tuning headaches. If you hook a clear length of hose to the bowl drain crack the drain screw and hold the length of hose alongside the carb you can see where the fuel level is at rest and then see where it is when the engine is running. While running level should be just below bowel gasket seam. If the level holds steady and then shoots up your valve and needle are probably failing or it's your float. May not be the problem but worth checking just in case.
P
pancho del rancho
Thank you for shedding some light, gentlemen. Tech day is tomorrow, I'll keep you posted.
R
Ross
I am running a 142.5, dynojet needle on 4th clip,3x3" airbox mod, 27.5 idle fuel jet, stock exhaust.
Runs great, much better then stockat sea level.
Too much gas would not cause a high idle. Turning the mixture screw in when it is already lean would shut it off completely. Cable freeplay ? How does it bog ? Pop in the intake when wacked ?=leanDid you check fuel level yet? You have the carb parts diagram ?
P
pancho del rancho
I figured it out -- the plug that holds the needle spring down wasn't properly seated. I am curious to see how someone like Ross' bike runs setup 142.5/27.5/4th clip when mine is running great setup 140/25/3rd clip with the 3x3 and stock exhaust. Interesting. Have to do a dyno test one of these days.
Thanks for the responses.
R
Ross
Maybe my hole is bigger then 3x3. I'll measure it .
