Flywheel Puller for 96+KLR650 needed
volcon
Hi all:
Looking to borrow or buy a flywheel puller for a 96 (or newer) KLR650 cuzI need to check my doohicky.
Can anyone help? Pls pm
TIA
Greg
Does either the front or rear axle fit the stator? I have run across a few bikes where some clever engineer matched the stator puller threads to one of the axles. In these situations one has to jury rig a spacer between the axle and the crank but can do the job in a pinch.
I have an 18mm bolt style puller in my toolbox if that is of any use.
volcon
Good idea Ron but the engineers at Kawasaki weren't "that" clever. The puller is a 22X1.5 bolt that threads into the flywheel and pushes (pulls?)it off of the crank shaft. I guess I could just go buy the right sized bolt but, I'd perfer to use the right tool as it is hardened and I really don't want to wind-up with a stripped bolt stuck in end of the flywheel:hr:
I hear you on that one. All you need is a lathe!:D
