Front wheel pinch bolt nuts?
RoscoeP
I'am just getting around to some mods on my bike and to getting rid of the "death wings" I got the tires (MT-21's) changed over and was putting the front wheel on. The book says to torque the front axle then tighten the top pinch bolts first then torque the bottom pair. So if you do this there is only a space on the bottom half of the clamp correct? or should there be a small gap top and bottom.:?
It's also a bit akward trying to line up the rotor, hold the speedo cable in place and make sure the spacer dosn't fall out, any tricks to make this easy? Cheers :hb:
P
Pirate
Practice............Sorry mate.;)
Buck
Yeah Expereince..youll do it without thinking after a well. I never owned a bike that has been dissasembled so often. Just switched back the IMS tank, Corbin Seat, front TKC80, new pads, different sprocket, retune supertrappp new base gasket, on and on, get used to it. its easy.
BMWNut
Just one suggestion, after installing the front axle but before you torque the pinch bolts down, give the front end a few good bounces to shake things back into place. This will avoid any unnecessary "twist" being locked into the front end.
RoscoeP
Thanks for the suggestions. I had a great day out in the garage yesterday. My wife calls it puttering. But to me it's alot of fun, I have a resonably nice garage with pretty good tools. My dog likes to come out and keep me company, throw in a beer or two and what more could I ask for. I borrowed one of those Cdn. tire bike lifts, the big heavy sucker and that was real nice to work on. Next sale one will be mine. Still to go on, sproket, handlebars and gaurds and rejet. Pipe I ordered was not available, have to figure plan B on that one. Cheers:hb:
