The ability to loft your front wheel over an obstacle at low speed (ie crawling along in first gear) is one of the most useful things you will ever learn how to do for riding off road. Gearing up will reduce that ability. So just go out to some level field and practice lofting the front wheel. Just stand up on the pegs, blip the throttle, pull back on the bars, and get your butt as far back as you can. Let the front wheel get a foot or so off the ground and then let it back down. Keep your foot ready on the rear brake and if the front end comes up too fast, engaging the rear brake will bring it back down. Do this over and over again until you're really comfortable with it. Try doing it over puddles, then move up to small dia logs (about 6 inches in dia) gradually increase the size of the obstacle until you're really confident with the technique. And don't be impatient, it'll take you several weeks or more to get it down. When you get really confident with the technique you'll find that you've also learned how to control the throttle and out of control rocket launches will be a thing of the past. It just takes time - practice, practice, practice.
John
