Inexpensive Braided Steel Brake Line for my DT200R!
gt750
While looking around for a local Company to make me a custom front brake line for my ancient 1990 DT200R, I went onto Amazon.ca, then found that I could order the length I needed, in 10mm increments, with 3 choices of angles for the 2 end banjo bolts. It cost me $26.00CDN delivered! I had to buy another item to increase my order to the minimum, though.
I thought it would be a cheap experiment if it never worked out. But, I am very impressed with the products quality, as well as fit. Definitely worth looking into.
red_si
That's a great find! I have a '96 DT200R, probably with a near original brake line. I love it and intend to keep it going for as long as possible. Did you buy a line for the rear brake too?
gt750
No only bought line for the front.
Also, tried to respond to the PM. Wouldn't seem to work? I am also on the "IT Forum." I ordered the front line with a zero degree fitting at the caliper and a 12 degree fitting at the Master Cylinder. I used a piece of string to trace the length. I believe it was around 1400 m.m..
