KTM640 Adventure/Carb question
P
pacificboy
My 640 started making a lof of backfiring a lot whenever I decrease speed. Last week I tried to removea carbto seeinside by myself but I could not remove it because of a few questions.I anyone knew answers for followingplease kindly teach me:
1. Do you take the carb from the top or from the side of the motorcycle ?
2. There is a choke cable going into the carb. I guess I must remove this to take the carb out of the motorcycle. How do you remove this cable ? Do you remove it at the carb ?
Thank you in advance.
A bit of a pain to remove the carb on a 640, but here goes: first remove vent tube from frame above carb and move it out of way, next unscrew top cap {2 screws} and carefully remove diaphram/slide assembly, next loosen manifold clamps so carb can rotate, remove throttle cable mounting plate {2 screws} angle screwdriver works or rotate carb a bit to get at heads then once loose you can remove the two cable end toggles from the rotating cam, next remove choke/enricher by loosening collar nut with a 12mm open end wrench{ a little tight for working in but doable} once loose the cable piston assembly should slide out and can be carefully moved out of the way {keep good track the the little piston and spring so it doesn't fly off upon removal}, next remove the two vent tubes off the upper right side of carb, next remove throttle position sensor {2 screws} and note its position for reassembly, remove fuel supply line, next rotate carb so you can get at the float bowl screws from the manifold side, remove idle thumbscrew, remove floatbowl {2 screws} and carefully pull down and remove float cage keeping track of the needle, unscrew the main jet so it doesn't hang up. Now the carb should be small enough to pop out of the manifold and rotate up between the frame rails. Clean out the jets and passage ways with spraycan carb cleaner and air, stubborn clogs can be removed with fine wire . Popping on decel usually means a lean condition, check to see if your slide diaphram is not torn {do before carb removal just in case},make sure your slide needle is set near the middle clip position. Also your pilot jet could be partially clogged or if equipped with a fuel pump make sure your vacuum line from the pump to the manifold is not leaking. Also check for exhaust leaks. Also if you've done any airbox/muffler mods without jetting changes this could cause a lean condition. Reassemble in reverse order and be carefull not to bump the float tang out of adjustment as proper floatheight is a very important part for 640 carb tuning. Told you it was a pain, good luck...
P
pacificboy
Island Hopper,
This is great ! Thank you for giving me step by step instruction. Now I have to wonder if I could do this by myself or not. I will work on it this weekend. Have a good weekend.:hb:
Some owners remove the carb in one piece by detatching the subframe and pivoting it back, I think this method is more of a pain than my method, and besides usually the reason for taking the carb off is for disassembly and cleaning in the first place. Let me know how it goes, if you decide to tackle this job { not so difficult}.
P
pacificboy
Yes, I was able to remove the carb in one piece. Screws for sensor were seized so I could not remove it from the body so I ended up removing a whole carb. In any case Your advise really helped me opening up the carb. I cleaned up everything.It still does more popping than what itused tobutit runs much better.Thank you.
