Julius
Hey, :ted:
There are two basic types of water proof clothing;
My little tec-tip is about the barrier type clothing.
Some jackets will have a removable liner, some it's built in. At the time of production the seams of the jacket or pants are folded over several times and stitched together, then a seam sealing tape is applied to ensure a water tight barrier.
Please see photo [url]http://www.dualsportbc.com/photogallery/data/654/184Dec_07_013.jpg[/url]this showes a typical seam with tape. Over time the adheisive of the tape starts to let go. Not alot, enough to let small amounts of water in, then you start spraying 'water proof' spray at the garment in hopes of sealing it. Mostly you will have poor results.
The next photo shows the user side of a seam, you can just make out the line of the tape and the little wrinkles where the tape has let go. My Joe Rocket B6. [url]http://www.dualsportbc.com/photogallery/data/654/184Dec_07_017.jpg[/url]
I use McNett's 'SeamGrip' urethane adhesive seam sealer. Available at most outdoor stores. See my notes on boots http://www.dualsportbc.com/forums/forum32/5005.html
I apply the seam seal to the user side of the garment. The tape side is usually behind fabric or other wise hard to get to. On my jacket this is on the inside. See next photo. http://www.dualsportbc.com/photogallery/data/654/184Dec_07_020.jpg
On my pants I applied it to the exterior. See next photo. http://www.dualsportbc.com/photogallery/data/654/184Dec_07_015.jpg
I have one wet ride with the pants, seems to work well. Soon I'll get the jacket out see how it works.
I hope this helps. Keep your roost up !! :dr:
- Gore-Tex type, water proof by the weave and a chemical additive. Breathable and Expensive. Can be re-water proofed at home, best done by a professional.
- Barrier type, a vinyl type coating on nylon, most of the water proof gear out there, not breathable but cheap(er). Not really re-water proof-able, but repairable.
