Sherco 4.5i
Today I fussed with the new Sherco installing hand guards, tank bag, wiring grips and generally tinkering. It seems built for Acerbis parts as there was ample room for the "bark buster" clamps and the comfortable grips have molded in grooves for safety wire.
The bike is generally uncluttered and although the battery is buried in the bottom of the air box, you can get to it with no tools as the seat comes off with a 1/4 turn DZUS fastener and the filter element is held in place with a unique "pogo" stick.
All fasteners have drilled heads to help keep the weight bearable. Speaking of weight, 275 with half a tank of gas including both electric start and kick start.
It starts with a prod of the start button and of course no fuel valve or choke to deal with as it is fuel injected. No jets to change, no lean idle stalling.The exhaust emits a subtle rumblebut never becomes obnoxious. First gear is trail friendlyseeming a little lower thanmy old KX250 geared for the woods.Sixth gear is supposed todeliver 95top speed and that's miles perhour. How is that for versatility?
Kayaba Paolisuspension on the front and Paoli on the rear, Excell rims, Michelin DOT knobbies, rim locks, hydraulic clutch and electronic dash board with a handlebar mounted button for zeroing your trip meter or changing modes. Cool red backlight for those late evening (night?) rides.
I will provide a more in depth report after the first "serious" ride.
RW
another pic
Here is a shot of the powerplant. The compact fuel injector creates an uncluttered look. Stainless exhaust and aluminum silencer.
Cool Bike ..Never heard of Sherco? Where is it made and how much.
Taxguy
Looks like a great bike:tup:, we have 2 Shercos in the garage (trials) and they have been great bikes.
What sort of fuel range do you get with the stock tank?
And are they generally know to be reliable? A quick search did not get me too much info.
But i want a lightweight dualsport, that is darn near a pure dirt bike, just able to be on the road, but also reliable.
Ntl#1x4
You are absolutely right, some Shercos are made in Spain BUT not all Shercos are made in Spain. I have both a Sherco 2.9 Trials made in Spain and the 4.51 made in their factory in Nimes, France.
To learn more about Sherco's factoriestry this link:
http://sherco.com/factories.html
:tup:Dualsport even has athumbs up sign just like the earlySherco's which were branded under the Bultaco name.
Cheers....Ron
B
blackelmo
They only produce 3000 trials bikes per year. No wonder trials bikes can be difficult to find! It's hard to believe there isn't more demand than that worldwide over the entire displacement range.
I have gone as far as 120 km on a tank but try to keep it to 100 km or less if there is any amount of single track.
Last 100 kmrefuel it took7.2 liters which should have left 1.3 in the tank. That ride had about 2 hours of single track on Blue Mountain mainly in first and second gear.
About 14 km per liter or 7 liters per 100 km or roughly 40 miles per imperial gallon.
I finally completed my skidplate project for the Sherco 4.5i. Fabricated from 3/16" aluminum I designed it to hug the frame and maintain the narrow profile of the Sherco. Mounts are stainless.
other side...otg
Thanks for the complements. I chose to use vertical risers on the sides to create a "box" form which should be pretty robust and stronger than the typical flat plate with wings. Using a rolled glide plate should allow it to slide over logs reasonably well and I think is more attractive than the typical plate with three or four brake bends to achievethe framecurve. Material is 0.188 (3/16") 5052-H32 aluminum.
Without crash testing it, it would be hard to say how the side deflectors will work.Hopefully,Idon't get to test them too often. I decided not to adorn it with holes and slots as those just let in more mud and debris. I will probably stuff it at the front withclosed cell foam to keep the mud from accumulating. I insulated it from the frame with some neoprene tape to keep it as quite as possible.
Now I need to figure out how to build one for the bimmer x-cross 450 (not that I am getting one, but I think a few people may be looking for one soon).
