You could use a Supertrapp ISD2 Quiet series or, if you want it louder, a Race series. If that's not loud enough get a Jardine but your bikecould excede the 96dB sound level limit. A re-jet will be neededwith a Jardine.Re-jet might be needed withaSupertrapp depending on the number of baffles used. There are lots of otherexhausts but I'm only familiar with these two.
I've got a Supertrapp ISD2 Quiet series and I'm very happy with it. The bike has more bottom end, response is quicker, throttle is linear,it is somewhat louder (but not too loud) and it shaved nearly 2kgs from my bike.
If you're on a budget, you can drill the bafffles out of the stock muffler but, it doesn't make much difference.Doing so will remove the spark arrestor which makes you a forest fire hazard.
As for what gives you that "classic sound" depends on what you think.
