KTM690R - No start - argh!
100milehowie
Make your last tank fill up of the season premium fuel (I like Chevron) and you will have far fewer problems getting started and running properly again after storage.
Rib Eye
Well,Joker & I took a second look & decided to try a new sparker, but ---- no luck.
Dumped her off at RTR (aka - the dealer)
Stay posted
RocketMan
Stay posted
Could have tried starting it with gas cap open?,something plugged in Exhaust?.Remember seeing a mouse nest in buddies XR airbox once ewwwww.
The plug was looking wet(maybe not wet enough?)
We dumped some fuel in the cylinder and it tried to fire but did not catch and the plug stayed wet.
It was firing enough to get the pipe warm.
Rob.....U DID have the filter out....RIGHT ? :rolleyes:
RocketMan
Vapor lock?,the bad thing about the 690 is tank,air filter not easily accesable.Im sure this would be as simple as putting gas in jug and air filter out then try to fire.Cant wait to see what Ross and Terrys says.
Rib Eye
Yes, I did try a few times with the air filter out.
RTR Parts guys mentioned it might be the fuel filter???
But then he back tracked & wasn't sure the 690's had one - if there is its probably in the tank
Dorky
Yes, 690 fuel filter is in the tank. It's a bit of messing about to change it but not too bad. I replaced mine last year and it was very dirty but I don't think it would stop the flow of gas. I guess it depends on how much dirt you drop into the tank when you fill it.
Rib Eye
Well, the boys at RTR got her running as good as new.
Fuel shutoff solenoid was stuck closed or partially open. I would have never guessed.
Thanks RTR!
farmerger
Thanks RTR!
Is that an ignition thing so that if you don't have the key you can't start the bike?
