I think everyone is providing wonderful advice but I think the next step is to properly measure the parts. This is a high tolerance, high performance engine. The piston might well be oval ground and you need to know how and where to measure and as sparkle suggests, measuring ring end gap is only a small part of assessing what needs replacement. Ring end gap is usually performed using a new set of rings as a quick and dirty method of assessing cylinder wear. Cylinders do not wear symetrically, they will typically become tapered over time, pistons wear as well. As far as guides go, if you don't have the tools or expertise you are only guessing. I would do as Island Hopper suggests and Mongoose is about as good as it gets for Yamahas. Once you know what you are up against you can make sound decisions on what or what doesn't need to be replaced. Also agree that the valves and seats should be left to a pro to get the proper angles.
My 2 cents and as always good luck with your repairs.
